Previous in Forum: Milk Protein Testing   Next in Forum: Small Galvanizing Plant
RED ONE 4K camera, do you have any experience at it?
03/11/2008 11:45 PM
any developement on it? how much is it now?
Pathfinder Tags: cemera
Canada - Member - New Member
Good Answers: 11
Re: RED ONE 4K camera, do you have any experience at it?
03/12/2008 6:52 AM
This is truly an impressive system!
03/12/2008 9:11 PM
Have you seen the movies shooted by it?
any difference between on 35mm film and it?
Good Answers: 11
03/13/2008 10:32 AM
I think that perhaps higher dynamic range and resolution is possible with silver halide film, but this is for real special applications and processing.
The photos and films on the site look real good fop JPG, I can just imagine the RAW 4K format looks like.
As explained in the link bellow, the adoption of 35mm size sensors enables the reuse of existing optics. There is surely a color correction to apply, as for 35mm still film cameras optics used for digital.
See this link for other products of this type: http://en.wikipedia.org/wiki/Genesis_(Panavision)
03/13/2008 9:18 PM
I cannt access the wili web site, but I get some materials from ohter relative site.
I cannt view real effect from these net, as you know the resolution on the net cannt reflect the real HD.
I hope to know is it spreading out in the theater in north america area? and getting popular?
Good Answers: 11
03/13/2008 9:59 PM
I hope I will not get us in trouble...
The filmography and competitors sections are quite interesting to show how much this technology is catching on. It provides immense flexibility to the film makers.
I was particularly impressed by the Vision Research products. The speed is quite an achievement.
Genesis (camera)
From Wikipedia, the free encyclopedia (Redirected from Genesis (Panavision)) Jump to: navigation, search
This article may require cleanup to meet Wikipedia's quality standards.
Please improve this article if you can. (July 2007)
The Genesis is Panavision's high-end digital movie camera, which uses a proprietary, full frame 35mm-width, 1.78:1 (16:9) aspect ratio, 12.4-megapixel RGB filtered CCD. It was first used by a feature crew to shoot Bryan Singer's Superman Returns and was shortly followed up thereafter by the World War I film Flyboys. However, the CGI-heavy nature of these two movies meant that ultimately the comedy Scary Movie 4 was the first theatrically released feature sourced primarily from the Genesis camera. Genesis has since been used by cinematographer Dean Semler for shooting Click and Apocalypto.
Contents [hide]
[edit] Background
Unlike the 2/3" 3-CCD RGB imaging system used in the CineAlta HD-900F (used in Attack of the Clones), the Genesis uses a single 12.4 megapixel CCD chip with the same width as a Super 35mm film frame. The "Panavized" CineAltas didn't use Panavision's existing range of 35mm film lenses and have different depth-of-field characteristics.
Most photographic lenses designed for film cameras cannot be adapted to work on 3-chip video cameras. In many cases, the prism block simply leaves no room for the rear element of the lens. In cases where the lens does fit, the resulting optical aberrations created by the prism (primarily spherical) would destroy image quality. Apart from this, the sensors on a "2/3 inch" video camera are closer in size to a 16mm film frame and so would produce a similar depth of field.
Panavision originally tried to overcome this problem with optical adaptors that fitted between the cine lens and the video camera but these have all produced an unacceptable drop in image quality. Most productions using the Sony HDCAM cameras therefore used lenses of Zeiss, Angenieux, Canon and Fujinon.
Apart from this, there were a number of operational problems with both the lenses and cameras used for Attack of the Clones, and so for Revenge of the Sith, George Lucas severed his long-standing relationship with Panavision in 2003, obtaining newer-model Sony HD F950 cameras and lenses from Plus8Digital instead.
In an attempt to address these and other problems, Panavision followed this up in 2004 with the Genesis, a full bandwidth (4:4:4) camera with improved colorimetry and sensitometry-related specs and, probably most importantly, a Super 35 mm film-sized recording area, thus making it focally compatible with regular Cine Primo lenses and giving a true 35 mm depth of field.
[edit] Technical specification
The Genesis uses a 12.4 megapixel CCD chip, arranged in a 5760x2160 horizontally RGB filtered array. The vertical resolution is cut in half to 1080 by pixel binning, so the final output pixel resolution is 1920x1080, about 2/3 the resolution of a 2k film scan. The chip has an HDTV-style 16:9 (1.78:1) aspect ratio, similar in size to Super35 3-Perf film. The CCD active area is .930 in. x .523 in. This is a significant breakthrough in that it allows just about any Panavision spherical 35mm cine lens to be used. However there are as yet unanswered questions about the resultant color quality, since single-chip NTSC and PAL color cameras using the exact same color-stripe sampling technique have always performed poorly compared to equivalent 3-chip models. The main imaging module of the Genesis is made by Sony, but the exact relationship between the two companies is unclear, since their joint partnership was dissolved in 2004 with Panavision's re-purchase of the 8% shareholding Sony bought in 2000.
The Genesis can record in a custom Panalog color space, which is a log color space that it is also 4:4:4 unlike traditional HD. The tone-curve is different than the Cineon log format used for film post-production, but preserves highlight detail that would be lost with typical video gamma correction.
There have also been numerous complaints about the small black and white viewfinders available, which are virtually useless for critical focus. To address this, Panavision uses the Sony HDVF-C30W TFT color LCD viewfinder (960x540 pixels), and is compatible with both the CineAlta and the Genesis cameras. The D-20, Arri's answer to the Genesis, incorporates a reflex optical viewfinder to address this concern.
[edit] Filmography
Feature films shot with Panavision Genesis include:[1]
Television series shot with the Panavision Genesis include Night Stalker, Conviction, What About Brian, Justice, and 3 Lbs..
Some television pilots shot with the Genesis include Faceless, In Case Of Emergency, Brothers & Sisters, 52 Fights, and Protege.
[edit] Competitors
Panavision has many competitors. Several competitors have very similar features and some are already in wide use by the film industry.
[edit] In development
[edit] Further reading
For detailed information on the Genesis, see the Genesis page on the Movie Making Manual WikiBook.
[edit] References
[edit] External links
  • Genesis Information from Panavision Australia including FAQs
  • Superman Returns Photo Gallery
  • Panalog After Effects plugin
  • PanaLog4Lin macro An Apple Shake macro for transforming an image from PanaLog4 space to 'Linear to Light', and back again
  • pvdocs.com - Download current documentation on the Genesis camera : user manual, FAQ, how-to Quicktime, interactive menu simulator, white papers...
Retrieved from "http://en.wikipedia.org/wiki/Genesis_%28camera%29" Categories: Digital movie cameras Hidden categories: Cleanup from July 2007 | All pages needing cleanup Views
Personal tools
Navigation
Interaction
Search Toolbox
03/14/2008 5:04 AM
Its kind of you to copy the context.
Good Answers: 11
03/14/2008 6:37 AM
No trouble at all, just doing my part as Wikipedia is the sum of many-many little and larger efforts in hope of spreading knowledge around the world.
Register to Reply 7 comments
