Previous in Forum: rubber and plastic   Next in Forum: power system restructuring
POWER CALCULATION
03/13/2008 5:37 AM
HOW TO FIND REQUIRED KVAR WHEN PF AND KW IS KNOWN?
Re: POWER CALCULATION
03/13/2008 6:15 AM
1) Turn off Caps Lock.
2) Arithmetic. Divide kW by pf.
Innuendo is not Italian for a suppository.
Good Answers: 61
03/13/2008 1:52 PM
KW/pf = KVA, not KVAR.
Derivation:
KVA = √(KW2 + KVAR2)
KVA2 = KW2 + KVAR2
KVAR2 = KVA2 − KW2
KVAR = √(KVA2 − KW2)
Since KVA = KW/pf, substitute in the preceding line to get the equation at the top.
03/13/2008 8:23 PM
Another way:
kVA = kW/PF
PF = √ (1-RF2) ; where RF = Reactive Factor
The same way, RF = √ (1-PF2)
KVAr = kVA X RF
Therfore:
kVAr = (kW/PF) • RF
Ain't that simpler?
Good Answers: 61
03/14/2008 8:46 AM
Your approach will certainly work. Not knowing the training/experience of the poster, I was trying to limit the final formula to the two known values. Even so, substituting for RF in your formula gives
kVAr = (kW/PF) * √(1-PF2),
which is still simpler than my approach. It requires fewer calculation steps & reduce the possibility of a math error.
Thanks, SC!
03/14/2008 1:10 AM
One way to find required kvar when pf and kw is known is where:= Initial Power Factor Angle, = Final Power Factor Angle (desired pf) but this is not the only way to calculate capacitor bank required for correction of pf, other factor too has to considered such as capacitor voltage, Capacitor Reactance, THD to name a few.
manirul
New Zealand - Member - New Member
03/15/2008 4:33 PM
Power factor is the ratio between KW and KVA.
There are two components of power factor, displacement power factor and distortion power factor.
Displacement power factor is caused by inductive or capacitive loads and is the cosine of the angle between the voltage and the current.
Distortion power factor is the result of electronic circuits on the supply that distort the current waveform. Switchmode supplies and VFDs are both sources of distortion power factor.
If you are sure that the quoted PF is displacement power factor only, then you can use triganometry to calculate the KVAR of the load. If you apply static correction to a motor, it is very important that you only correct 80% of the KVAR of that motor. see http://www.lmphotonics.com/pwrfact.htm
Best regards,
Mark Empson
http://www.LMPhotonics.com | http://www.LMPForum.com
03/26/2008 12:42 AM
Hello Guest,
Assuming your load is 200 kw @ 0.8 pf, and you need to make ithe pf 0.95,
Required kvar = 200 ( tan { cos inv (0.8)} - tan {cos inv (0.95)}).
Now you take it ahead from here...
Cheers.
PS : Avoid using CAPS as human eyes find them disorienting...!!
He must be very ignorant as he answers all the questions he is asked. Voltaire
chaterpilar (1); Horrible Old Bat (1); manirul (1); marke (1); pwr2thepeople (2); southerncomfort (1)
