Previous in Forum: busbar insulation   Next in Forum: POWER CALCULATION
rubber and plastic
03/13/2008 4:06 AM
where can i get the information about the uses of rubber or plastic or combination of both in electrical area?
Re: rubber and plastic
03/13/2008 4:25 AM
They are insulators. What's the problem?
Innuendo is not Italian for a suppository.
Good Answers: 230
03/13/2008 4:34 AM
Hello Guest,
You use an Internet Search Engine, try Google -
http://www.google.com will get you right onto the job.
Search Terms: rubber electrical industry usage = Results 1 - 10 of about 363,000 for rubber electrical industry usage. (0.18 seconds)
Then you look at the results, to locate which information you require.
Likewise your other request:
Search Terms: plastics electrical industry usage = Results 1 - 10 of about 442,000 for plastics electrical industry usage. (0.19 seconds)
Please note I have bolded the Search Term words above, to make them clear for you.
In the Search Engine Search box, the words do not need to be bolded.
Using an Internet Search Engine is really easy, and a necessary art to learn, from the World's largest Library.
Because the Internet Library has now well over 50 Billion pages, and growing several millions of webpages each hour of the day and night, the need to use an Internet Search Engine is essential.
The Internet Search Engine is like asking the Librarian for information.
Enjoy the reading.
Kind Regards....
Good Answers: 59
03/14/2008 12:02 AM
Sparky is right. You cannot ask - successfully - a question that broad, and expect a meaningful answer. This website is set up to handle immediate and specific questions. If you for example ask, what type and size insulator should you use under a tall vertical antenna for a 50kW AM station, to be expected to work there for the next 50 years, you - in all likelihood will get a few very good pointers. Because it is specific!!!
Horrible Old Bat (1); leveles (1); Sparkstation (1)
