I changed out a set of service valves today on a 5 ton Heil H/P and added a bi-flow line drier to the line set. I weighed in the charge of 210 oz or about 13.13 pounds. The A/H on this system was changed out 2 days ago so coil and filter is as new. The temp. outside was 68 and inside 70 I checked pressures in cooling the were 62 low side and 175 head. But when I checked it in heat the low side was about 70 and the head just kept going up it was right at 400 psi. If I energized the r/v it would drop back to 62 & 175. This is a R-22 system. Any ideas? I'm thinking expansion valve but every one of those I have seen go bad would pull the low side down.
