Previous in Forum: gas flow meter/ oriface plate   Next in Forum: Water in crude oil
9 comments
difference between SS316 AND SS316L
03/14/2008 5:06 AM
IN WHICH APPLICATION SS316L IS PREFERRED OVER SS316.
L STANDS FOR WHAT.IN SS316L
Good Answers: 101
Re: difference between SS316 AND SS316L
03/14/2008 6:18 AM
Low carbon.
03/17/2008 12:31 AM
As said in post#1 "L" refers toLow Carbon Steel. Many Process instruments are made of this Low Carbon Steel. More info on Low carbon stell is given below. Low Carbon Steel It contains 0.2% carbon. Uses: Sheets, wires, pipes. low- or medium-carbon steel is used for sheeting and structural forms because of its amenability to welding and tooling. The other types of Steel are: Low-carbon steels, Medium-carbon steels, Ultrahigh-carbon steels. As a group, carbon steels are by far the most frequently used steels. More than 85% of the steel produced and shipped in the United States is carbon steel.
Blessed is the man who finds Wisdom, the man who gains understanding. Proverbs:3:13
04/01/2008 3:38 AM
L means that the C content is below 0.03% not 0.2%. This is a Stainless Steel and not a Carbon Steel..
The low carbon grade is used 'cause it has a better weldability and does not suffer of carbide precipitation (sensitization) for exposure to high temperature.
S.
Corrosion Control | Corrosion Protection
05/04/2009 11:14 PM
Very good,Your answer is exactly coorect.
04/03/2008 12:38 AM
When there is a danger of corrosion in the heat-affected zones of weldments, the low- Carbon variety of SS316L should be used.
04/03/2008 3:37 AM
usually when you've a welded construction you use SS 316L to avoid any problems of sensitization. The corrosion of the sensitized zone is a problem if you have a service with a corrosive fluid or environment, if it's not exposed to a corrosive environemt or fluid it could be not a problem.
S.
Corrosion Control & Corrosion Protection
05/17/2010 11:21 AM
Can anyone throw some light on how does SS316 & SS316L compare as far as cost is concerned?
07/16/2010 2:32 AM
UNTIL BOTH SS316 & SS316L ARE AUTENTIC STEEL WHEREAS DIFFERENCE BETWEEN SS316 & SS316L IS ONLY OF CARBON CONTENET.IN SS316 THE MAXIMUM CARBON CONTENT SHOULD NO MORE THAN 0.8% , WHERE AS IN SS316L CARBON CONTENT SHOULD NOT EXCEED 0.3%.BOTH YEILD STRENGTH & TENSILE STRENGTH ARE GREATER IN SS316 THAN SS316L.
DENSITY OF SS316 IS APPROX. 8.4g/cm-cube & OF SS316L IS APPROX. 8.0g/cm-cube.
07/16/2010 2:38 AM
SORRY.......THERE IS A SAMLL MISTAKE IN ABOVE MENTIONED SENTENCE .'''MAXIMUM CARBON CONTENT SHOULD NO MORE THAN 0.08% , WHERE AS IN SS316L CARBON CONTENT SHOULD NOT EXCEED 0.03%''', INSTEAD OF "MAXIMUM CARBON CONTENT SHOULD NO MORE THAN 0.8% , WHERE AS IN SS316L CARBON CONTENT SHOULD NOT EXCEED 0.3%".
Anonymous Poster (4); DVader1000 (1); Macsimus (1); PF_Technical_instr (1); strider6 (2)
You might be interested in: Stands and Supports, Over-the-Side Heaters
