Previous in Forum: difference of 50 hz and 60 hz machines   Next in Forum: Cordless Drill Battery
8 comments
India - Member - moorthi
Standard Electrical Panel Size
03/14/2008 7:26 AM
Friends,
electrical control panel has any standard size?
if yes, give me its details?
moorthi.
Re: standard electrical panel size
03/14/2008 7:59 AM
They usually come in widths from 300mm upwards in 100mm steps.
What do the control panel case suppliers have to offer?
Good Answers: 42
Re: Standard Electrical Panel Size
03/14/2008 2:35 PM
Hi Moorthi,
The standard size of Electrical control panel ,do you mean BIS standards or any other standard ? There are many types of electrical control panel and the size of the panel depends on the number and size of the components, voltage and quantum of wiring and where it is to be installed ( in door/out door) or where it is to be mounted etc. So if you can provide more details, more informative and useful reply can be provided. I mean you elaborate your thread.
03/15/2008 12:58 AM
Thanks ,V.I Abraham i don't know BIS and other standards, can you give me more details about these? or any link where can i read?.
Good Answers: 42
03/15/2008 5:10 AM
Mr. Moorthy,
Hope you understand ISI ( Indian Standard Institution )Now it is called BIS ( Bureau of Indian Standards) who specifies the quality of Indian Products. Once a product is marked ISI the quality of the product has to be manufactured confirming to that specification or that standard. All products are given an IS number. As an example IS 13947-1993 is the IS specification for Low voltage switch gear and control gear. These IS are framed in line with IEC (International Electro technical Commission) These standards are available in Indian Book stalls or Institution of Engineers office,and technical libraries for reference. If you are practicing engineer in India ,you must always have a copy available for reference.There are IS for all electrical products. These specifications are very good guide to execute any work.
If you want more information on the subject you can send personal mail.
03/15/2008 5:34 AM
Thanks for providing this data, if i have any more doubt, then i contact you.
moorthi
03/17/2008 12:56 AM
Thanks Abraham, what I understand is IEC 60947 has been copied to IS 13947 with copy write act. Hence you can also refer IEC. For MCC it has a standard size. But for a centralised control system control panel panel has no standard size. It depends what level of automation you are going to adopt. Normally manufacturers have their own standard control panel/desk, but at the same time they can fabricate as per project requirement.
BNDas
03/17/2008 12:50 AM
apart from what Mr. Abraham mentioned you have to be careful for the construction type of panel such as form 1, 2a, 2b,3a,3b,4a and 4b
manirul
03/17/2008 3:41 AM
thanks manirul, can you give me full details of 1a,2a.....?
moorthi
Register to Reply 8 comments
biswanath.das (1); manirul (1); moorthi (3); PWSlack (1); V.I.Abraham (2)
