Previous in Forum: please help me   Next in Forum: pv solar modules
moving coil and moving iron meters
03/14/2008 9:19 AM
why can we use moving coil voltmeter to measure a ac source but with moving iron we can measure both of em?
Re: moving coil and moving iron meters
03/14/2008 9:40 AM
Its how they are constructed//..
A moving iron meter will respond to both ac and dc voltages/currents through it.
A moving coil only responds to dc voltages/currents through it...
A moving coil can be made to respond to ac by recitfying the ac first...
I think you are getting a little mixed up perhaps?
John.
03/14/2008 11:27 AM
Have a look at these descriptions from All About Circuits. Explains it well.
Good Answers: 120
03/14/2008 11:46 PM
a moving coil responds to AC and DC. With DC it moves against the coiled spring until the spring balances the torque from the current.
With AC it moves a very little bit in one direction and when the current reverses it goes the other way. So it stays on zero and gets a little blurred. Quite visible on the old 25 hertz systems, but much less on 50/60 Hz. Lighter needles are more compliant and move more.
Per Ardua Ad Astra
03/15/2008 9:34 AM
can u explain the working of moving iron type meters?
03/15/2008 9:51 AM
The 3rd figure in the link I gave in the post above shows a form of moving iron meter. Here it is again, for your convenience:
As you will see, there is a fixed coil through which the current to be measured flows, and an iron vane attached to the pointer. The iron doesn't care what type of magnetic field is attracting it - AC or DC - but the higher the current, the greater the attractive force, so the greater the deflection of the pointer. There is a spring (not shown) which keeps the pointer at 0 when no current flows.
Anonymous Poster (1); aurizon (1); Electroman (1); JohnDG (2)
