Previous in Forum: Is my hot water heater on the fritz?   Next in Forum: Turbine Animation
strain gauge operated motor
03/14/2008 11:37 AM
i am trying to cteate a ciruit which drives a motor from the output of a strain gauge.i need the motor to remain still untill the output voltage reaches a set level, then once this level is achieved, the motor starts.
Re: strain gauge operated motor
03/14/2008 11:50 AM
Standard strain gauge bridge, amplified with an op amp. The output goes to one input of a comparator, the other comparator input goes to a potentiometer so that you can set the threshold. The comparator output switches a relay/ FET/Triac controlling the motor.
Good Answers: 183
03/14/2008 12:59 PM
Do you want to use a single strain gage? or can you use a half or full bridge?
Do you work under variable temperature ?
Do you accept a dispersion zone arround the strain nominal value?
You might be interested in: Strain Gauges, Strain Reliefs, Motor Test Equipment
