Previous in Forum: Scrap steel--does higher quality = higher scrap price?   Next in Forum: the recommendation velocity at the outlet of an diffuser in HAVC
How to calculate what size turbine for a known output
03/14/2008 5:35 PM
Sorry folk - I am not an engineer
But I have a need to make a compressed air turbine to turn a crank at certain torque:
That being a maximum of 20Nm / 180lb-in at possibly 4000 rpm
How does one work out how big the turbine needs to be?
Ideally I would like the unit to be as compact as possible.
How much air would it require to run for an hour?
I am just not sure how you would calculate these figures. Is it do-able?
Please could you point me in the direction of finding this information. Thanks
Re: How to calculate what size turbine for a known output
03/15/2008 4:09 PM
Hi
I have just learnt that - the turbine needs to operate within an optimal speed which must then drive a gear box which is used to drive the crank to get the desired torque.
So obviously this opens up a tremendous amount of possibilities.
Good Answers: 137
03/17/2008 5:09 AM
You're right about the number of possibilities. Sounds like you want the turbine to do 4000rpm (gearbox input), but need 20Nm at the gearbox output.
To calculate the power output, need to know gearbox output speed. Also to estimate the volume of air required, need to know air input pressure.
Codey
Good Answers: 15
03/16/2008 8:37 PM
Have you tried going to a local tool supply shop and inquire about a pneumatic torque wrench?
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
03/17/2008 5:59 AM
4000rpm = 420 radians per second.
420rad/sec * 20Nm = 8.4kW.
So the turbine needs to deliver a shaft output power to the load of this amount.
There are air-motors that will do this sort of delivery, so the answers to the remainder can be had by looking at various suppliers' information, including air pressure/consumption charts, prior to selecting a unit that will do the job.
Good Answers: 137
03/17/2008 7:26 AM
Hello PW - that power is correct if the 20 Nm is at 4000rpm, but his post #1 suggests it isn't, it's after a gearbox.
Codey
03/17/2008 5:33 PM
Thanks for all your replies - forums amaze me. An outpouring of help.
I think I have sorted it -I did some drawings and worked out volume of air in the turbine and from that was able to workout the Pressure required to turn the crank.
Pressure = Force / Area
So I 'll go an put my money in an engineers pocket to build it for me.
Your calculations were spot on from what I can make out.
Thanks again
Register to Reply 6 comments
Codemaster (2); PWSlack (1); Snaketails (1); zimrabbit (2)
