Previous in Forum: XFORMER SIZE, voltage drop   Next in Forum: Sizing Electrical Cables and Switchgear
DG Set
03/15/2008 1:55 PM
Is there any diesel generator set with 33KV output voltage,3-phase,50hz.
Pathfinder Tags: DGS
Re: DG Set
03/15/2008 3:28 PM
I don't think you can find that. As when I used to work in a steam turbine electrical power plant the voltage comming out from the generator was only 6kv. Why not use a step up transformer? that would be the most optimal solution.
A man wants to know everything about everything, a woman wants to know everything about everybody
Good Answers: 230
Re: DG Set
03/15/2008 7:27 PM
Hello pkmassar
It is normal for small Diesel Alternator sets to output at Mains voltage.
Larger units output at 3.3 or 6.6 kV.
Still larger units output at 11kV.
Power station Alternators output from range from 11kV to 13.6 kV approximately.
The reason is that as the internal Alternator voltage increases, the internal insulation requirements become far greater, and it is cheaper to use a step-up Transformer.
Most installations use a Transformer which increases the basic output from the Alternator to the Voltage required for transmission or distribution, at which load end, step-down Transformers reduce the Voltage to the required amount.
Transformers lose a small amount of energy, but if a fault develops they are more easily repaired, and it is normal to have one or more spare Transformers, which are easily exchanged when a fault occurs, in most installations.
The diagram below, shows the load end of a high voltage transmission line, note transformers.
Trust that helps you.
Kind Regards....
Re: DG Set
03/16/2008 2:08 AM
Excellent Explanation.
Regards,
Keyur P Shah
First do it and then talk about it
Re: DG Set
03/16/2008 3:32 AM
Max voltage is 11KV in DG.Generators of higher voltage iam yet to come across.I had seen the offer for 33KVmotor for one of the projects from Hitachi.
Re: DG Set
03/16/2008 6:14 AM
Yes, of course there are - I know some from 3MVA to 11MVA.
Which power do you need ?
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Good Answers: 19
Re: DG Set
03/16/2008 10:52 AM
Re: DG Set
03/17/2008 7:24 AM
Thanks .Its a good reference. It was useful.
Register to Reply 7 comments
keyur_197 (1); MOURADIG (1); nesubra (2); PetroPower (1); Sparkstation (1); uweka (1)
