Previous in Forum: Air compressors air pressure out of the compressor itself???   Next in Forum: Hopkinsons Torsion Bar Safety Valves
vibration damper
03/16/2008 1:46 AM
I want to mount a rotary piston vacuum pump on a moble trolley. It gives very high vibration and all the fittings are getting loose. Please suggest a suitable vibration damper.
Good Answers: 143
Re: vibration damper
03/16/2008 5:33 AM
First, why does the pump have such high vibration that fittings come loose? That's not normal and suggests something wrong. But, after you fix that, tell us something about the size (weight) and hp of this beast.
03/17/2008 8:36 AM
I pressume you are using hoses in conjunction with the fittings. If not, this might be the culprit.
Or, try using engine mounts or rubber bushings.
03/17/2008 9:16 AM
Paint shakers at hardware stores use springs on the bottom. They seem to prevent most of the vibration from transferring to tables, etc.
Nothing exceeds like excess.
03/17/2008 11:43 AM
This might help
http://www.fabreeka.com/
Sucess is going from failure to failure without loss of enthusiasm... Winston Churchill
Good Answers: 97
03/23/2008 9:03 PM
Bulls eye
bwire (1); Jaguar (1); Nelson de Leon (1); Q (1); TVP45 (1)
