Previous in Forum: Using Polyurethane with a PVC covering.   Next in Forum: TERMAL BARIYER COATING
Unti friction coating
03/16/2008 1:57 AM
What is the best coating for aluminum 6061-t6 to get a smooth sliding between 2 parts (minimum friction)
Thanks
shimon weinrich
Israel
Good Answers: 143
Re: Unti friction coating
03/16/2008 5:29 AM
You haven't given enough info to give a definitive answer. For example, if the normal pressure is quite low and you're looking only for a couple hundred cycles, hard coat anodize might work as an expediency. Frankly, aluminum sliding on aluminum is an awful design and I'd change that if I could. But, let's say you have no choice. In that case, I'd put a ceramic coating (flamespray) on both parts.
Good Answers: 183
03/16/2008 1:00 PM
There is a possibility to use a PTFE doped hard coating friction coefficient is 0.04.
The plants doing the hard coating (at least some of them) do the doping as well. I thing it is the best choice for you since the price is not excessive and the thermal load is the same as for hard coating.
Good Answers: 58
03/17/2008 7:49 AM
Many industries including the firearms manufacturers have found that electroless nickel plating provides a slick, low friction, wear resistant coating on aluminum.
03/18/2008 9:38 AM
Rulon material, made by Saint-Gobain Polymer Products, bonded to one of the pieces and lubricated is a standard method used in machine tools.
Good Answers: 183
03/18/2008 6:41 PM
I forgot to mention a nickel plating as well with imbedded PTFE. I am not sure but i think magnaplate does it. I used the hard coating with PTFE but not the nickel. I had very good results.
davlamb (1); nick name (2); TVP45 (1); welderman (1)
You might be interested in: Aluminum and Aluminum Alloys, Coating Services
