Previous in Forum: Mechanical Engineer   Next in Forum: Geared motor query
Disadvantages of using Bulb Turbine for Hydropower Generation
03/16/2008 10:42 AM
If choice of hydro turbine is focused on kaplan ( Vertical / Horizontal / S Type ) and Bulb Turbine , can any one tell the disadvantages of using Bulb Turbine ? Which are the normal and specific problems experienced if Bulb Turbine is installed ? There is not much advantage of efficiency if we use Bulb Turbine. However use of such Turbine in a country like India , serious operation and maintenance problems may nullify the marginal efficieny of Bulb Turbine.
Please share your experinece.
Re: Disadvantages of using Bulb Turbine for Hydropower Generation
03/17/2008 12:46 PM
Yes, there is a revolutionary way to extract water current energy, as well as wind energy. It could make all other wind/water energy production techniques obsolete! It is Called the WindWing, and was invented by Gene Kelley. http://www.rexresearch.com/kelley/kelley.htm
