Previous in Forum: Psychrometric Chart   Next in Forum: Disadvantages of using Bulb Turbine for Hydropower Generation
Mechanical Engineer
03/16/2008 8:36 AM
How do you push a rope?
Good Answers: 143
Re: Mechanical Engineer
03/16/2008 8:38 AM
This should be moved to the Management Engineering forum.
03/16/2008 10:13 AM
By any method you might use to PUSH anything!!!!!
Bud Trinkel
03/16/2008 11:06 AM
Become an alcoholic!
Good Answers: 101
03/16/2008 10:08 PM
One way would be to tie one end to a rigid object, then push the rigid object. The most common way though is to use the extremely popular management technique, "Fool's errand".
03/17/2008 5:49 AM
If management gurus can "push the envelope", then anything is possible.
OK. Here's one. Wet it and freeze it.
BudT (1); ckartson (1); DVader1000 (1); PWSlack (1); TVP45 (1)
