Previous in Forum: energy saving tubine air ventilators   Next in Forum: Mechanical Engineer
Psychrometric Chart
03/16/2008 8:13 AM
can i use the pyschrometric chart for 100KPa, even if the air is blown thru fan?
the air pressure increases when blown by fan, right?
will there be a [B]difference [/B]in change in enthalpy? (for charts at 100 Kpa and at higher pressure, with same dry and wet temp)
:wall:
Good Answers: 137
Re: Psychrometric Chart
03/17/2008 4:54 AM
I would say yes. 100kPa (assuming you mean absolute, not gauge) is about atmospheric pressure. A fan only likely to raise this by about 1kPa (depending on fan type) so doesn't make a big difference.
Codey
03/17/2008 5:51 AM
To a good first approximation, yes.
03/17/2008 6:22 PM
the fan that i will use is from the window-type air con running at 1050rpm. do you think that using the 100Kpa chart is still a good approximation?
Register to Reply 3 comments
Codemaster (1); misterio (1); PWSlack (1)
