Currently I operate a Gap Face Grinding (special process with speical abrasive)process, basically for a piston rings used in automobiles, with a stock removal of 0.2mm/Pass. On some occasions I go up to 0.4mm/pass due to which I see burn marks in the component. Can anyone tell me what are the adverse effect of this problem on the component (assuming the component is visually acceptable)?
