Previous in Forum: Renewable Energy Masters   Next in Forum: Daytime TV ad's, who buys this stuff?
How to solve the Vapour lock problem in Deareator.....!
03/19/2008 12:23 AM
Brief description of our system: We are having three STG sets(STG-1,STG-2,STG-3) of each 15MW capacity. And there is common Deareator for all the three sets with feed pumps for individual sets. For deareating water we are using bleed steam from STG-3 to common deareator and whenever threre is tripping of STG-3 there is non availability of steam for deareator and causing the vapour lock in other two STG sets Boiler feed pumps and tripping of other two units(STG-1 & STG-2) due to vapour locking problem in respective STG BFPs.
Re: How to solve the Vapour lock problem in Deareator.....!
03/19/2008 5:45 AM
Your question is a bit puzzling? A three stage turbine is a reheat? but you have three feed pumps? and a common feed range. and feed heater steam from STG-3? can you please explain?
Regards JD.
Safety - Hazmat - PHA / HAZOP Facilitator Engineering Fields - Chemical Engineering - Principal Engineer Engineering Fields - Piping Design Engineering - Chemical Process Engineer
03/20/2008 10:53 AM
I tend to agree that this problem is likely too complex to bridge the obvious language barrier. A flow diagram would help.
That being said, I think you need to reconfigure for addition of emergency back-up heat to the deareator.
Of course, a detailed review by an experienced chemical engineer specializing in water treatment couldn't hurt (shameless plug ) www.bradleyventures.com
Stephan
Do what you will whilst harming none.
03/22/2008 5:16 AM
A common deareator is provided for all the three sets however the bleed steam for heating and devapourisation is taken from STG-3 only. Better practise is to take steam for common deaerator from a comman header where bleed steam of all the three sets are connected. This will ensure availablity of steam to Deaerator during tripping of any set.
Regards,
R.Thiyagarajan.
03/23/2008 10:41 PM
Its normal practice I think to refer to the development, or building, of a power station as being done in stages, so taking steam from STG-3 I think can be safely be considered to be UNIT-3. On the tripping of unit 3, I would speculate the following, (1) on loss of heating to the Deaerator the cooler water from the other units causes a partial vacuum in the Deaerator, (2) the other two units picks up the load, and there is a demand for the other feed pumps to put extra feed to the boiler, this will further increases the vacuum in the Deaerator causing a loss of head pressure to the feed pump suction?
Normally the Deaerator is placed at some higher level, and this should not happen, but if the demand is from a single Deaerator that is a bit small? then one can only speculate that the demand is greater than the supply from the hot well for a short enough period for the loss of head to occur.
Like I said this is speculation only.
Regards JD.
03/24/2008 2:10 PM
Try a mechanical vacuum pump for deareator !
jdretired (2); rajant_2001 (1); StephanChE (1); Stirling Stan (1)
You might be interested in: Die Sets, Circuit Breakers, Locks and Locking Systems
