Previous in Forum: how do i calculate cable size?   Next in Forum: induction motor
Power Requirement
03/19/2008 3:56 AM
Can any one help me to calculate demand power for the following load ?
SCHEDULE OF LOAD
compartmentCubicle
Designation
in
actual
Feeder
Designation
Load ServedKw LoadBreaker
Rating . AMP
10A/10Spear For lncoming lineNoneNone
feeder no ( 1 )
20B/1F1Generator # 1Control panel12753000
3AC/1F1-5Effluent Plant1063
3BC/2F1-85 Ton creane.Process area563Kw Load
3CC/3F1-10DB - STP106310
3DC/4F1-11DB - Ro plant10635
3EC/5F1-13Harmonic Filter500KVAR800
power factor correction
10
4AD/1F1-1Ups unit10 KVAR32
An Uninterruptible Power Supply
10
4BD/2F1-3DB-work shop3510035
4CD/3F1-7DB-pump house1410014
4DD/40SpearNone200386
4ED/5F1-8Thermal suit supply38680075
5AE/10SpearNone200150
5BE/20SpearNone200218
5CE/2F1-9Air Compressor # 17525037
5DE/4F1-2Coater suite supply15063040
5EE/5F1-4Preclean suite supply21863036
6AF/10SpearNoneNone10
6BF/20SpearNoneNone250
6CF/30SpearNoneNone72
6DF/40SpearNone25080
6EF/5F1-12Pressurisation fan # 13720037
6FF/60SpearNoneNone185
70G10Tie breaker # 1None300025
80H10Spear for incoming line(2)NoneNone
feeder no ( 2 )
250
90J/1F2Generator(2)control panel12753006250
100K/10
section for synchronisation
NoneNone37
11AL/1F2-3DB-SER Supply40100190
11BL/2F2-1DB-CR Supply36100120
11CL/3-SpearNone1005
11DL/4F2-9DB-DH1010036
11EL/5F2-10Fire pump control panel25080075
12AM/1F2-7DB-MB supply72200370
12BM/20SpearNone20022
12CM/3F2-4DB-PL supply8020025
12DM/4F2-616 Ton crean3720037
12EM/50SpearNone20010
12FM/6F2-8Fume exhaust fan supply18560010
13AN/10SpearNone1655
13BN/2F2-5Automax supply2563
13CN/30SpaceNoneNone
3177
kw
3.177mw
13DN/4F2-11Load bank2504003971.25k v.a
13EN/5F2-12DB-admin lannex250600
14P/10Tie Braker # 23000
15AQ/1F3-14Ups by pass circuit ( ups )10 KVAR63
15BQ/2F3-9Pressurisation fan # 237200
15CQ/3F3-4LTAC suite supply190630
15DQ/4F3-2Strip line drive suit1201250
16AR/1F3-55 Ton work shop crean563
16BR/2F3-15DB- exit pulpit36100
16CR/3F3-7Air Compressor # 275250
16DR/4F3-1Chiller unit package3701000
17AS/1F3-3Ro plant supply22100
17BS/2F3-6DB - L.P.G25100
17CS/3F3-10Pressurisition fan # 33725
17DS/40SpearNone200
17ES/5F3-13Harmonic Filter500 kvar800
18AT/1F3-11DB - LAB10100
18BT/2F3-12DB - Roll grind10100
18CT/30SpearNone100
18DT/4F3-8DB - paint store55200
18ET/50SpearNone200
18FT/60SpearNoneNone
190U/1F3Generator(3)control panel12753000
200V/10Space - c00
Re: Power Requirement
03/19/2008 9:09 AM
Appears a live project. and asking free consultancy?
BNDas
Reply Score 1 for Off Topic
03/19/2008 9:31 AM
Yes, though I can't be bothered to do the arithmetic.
03/19/2008 11:43 PM
Then Beat in the bush!!
BNDas
03/21/2008 12:57 AM
The load schedule in the above table is a TCL and to calculate TDL you have to analyze nature (continuous or non-continuous) of each load, duty cycle of the load from which you have to calculate demand factor of the load and over all diversity factor of the load. without knowing all these TDL can be calculate on the basis of thumb rule.
manirul
05/29/2024 7:11 AM
Certainly. A qualified local Electrical Designer can do this calculation. If one is not on the payroll, then the best thing to do is get on the phone, and find one.
Yellow Pages?
Anonymous Poster (1); biswanath.das (2); manirul (1); PWSlack (1)
