Previous in Forum: What Term for the vacuum created by flat surface passing over hydraulic   Next in Forum: Articulating Pneumatic Joint
Torsional Vibration Analysis Of Reciprocating Compr Driver Syst
03/19/2008 12:33 PM
Please tell me method in sequence. I will be very grateful.
Re: Torsional Vibration Analysis Of Reciprocating Compr Driver Syst
03/19/2008 12:47 PM
Please advise the make, model and size of the compressor.
03/20/2008 10:22 PM
COMPRESSOR MAKE: NUOVO PIGNONE
MODEL: 2HC/1
03/19/2008 7:30 PM
Motor driven or engine driven?
Den Hartog does a great treatment of this process useing Holzer tables. I suggest that you either purchase this book, or check it out from a university library. You can't go wrong with Den Hartog...
http://www.amazon.com/Mechanical-Vibrations-Dover-Books-Engineering/dp/0486647854/ref=pd_bbs_sr_2?ie=UTF8&s=books&qid=1205969280&sr=8-2
03/20/2008 10:15 PM
DEAR SIR
COMPR. IS MOTOR DRIVEN. CAN I GET BOOK CONTENT FREE BY USING INTERNET.IF SO PLEASE SUGGEST ME LINK. THANKS FOR REPLY.
MAHENDRA
03/21/2008 10:46 AM
Pignone should have done an torsional analysis, have you contacted them for the results?
The analysis involves determining the torsional stiffness and inertia of each part of the machine, and then from that determining the torsional natural frequencies. If there are forcing frequencies in the machine that match up with natural frequencies then the machine design must be changed.
MAHENDRA (2); PWSlack (1); Steve S. (2)
You might be interested in: Vibration Instruments, Vibration Sensors
