Previous in Forum: Share Market   Next in Forum: How many already and how many more? The great Hubble at it again.
Good Answers: 183
Miniature RF id System
03/20/2008 2:30 PM
Hi,
I need your help:
for a project I need RF id for a limited space. The tag and the antenna should be less/equal 10 mm(13/32") in diameter, if less it is better. The circuit should be as small as possible. The identification is thought for inserts in a portable tool which asks for a reduced current requirement and a sleeping mode with even less.
Did any body met such devices? I tried via Google (as I recommend to others to do) but I did not find any totally satisfactory combination. In position for identification the distance between tag and antenna is 1 to 2 mm (0.04"...0.08") only.
I shall be very thankful for any indication even if the comonents do not come all of them from same supplier
Nickname
Pathfinder Tags: miniature RF id
Re: Miniature RF id System
03/21/2008 2:09 PM
Veterinarians insert RFid tags in animals that are the size of large grains of rice. Try there.
Good Answers: 183
03/21/2008 3:21 PM
Thank you the tags are exactly how i want them there is still the antenna problem but i shall sove it
It helped a lot
Nickname
Register to Reply 2 comments
