Previous in Forum: Maintain machinery   Next in Forum: Boiler Feed Pump
boiler water
03/20/2008 11:44 PM
how water and steam is in equilibrium in boiler drum at 90 bar and 465 degree centigrade? state of water?
learning never ends
Re: boiler water
03/30/2008 1:06 PM
In a boiler the water is heated and is at the critical point where it is getting ready to change phase from a liquid to a gas.
You can go to the following link to find the critical point in your application.
http://www.spiraxsarco.com/us/resources/steam-tables/saturated-water.asp
Something that the above will not tell you, is why boiler carry over (when boiler water is sucked out through the boiler and into the header) occurs, and how it can be prevented.
For additional information on how a boiler operates, see the following:
http://www.spiraxsarco.com/resources/steam-engineering-tutorials/the-boiler-house.asp
I hope the above helps.
