Previous in Forum: Gas Panel   Next in Forum: Flash from the Past... Wondering...!
15 comments
small lightweight jack
03/21/2008 9:56 AM
I am developing a rolling device to aid in moving furniture. I am looking for a jacking device that is capable of lifting app. 500 lbs.,lightweight,has app. 12" of travel. Any ideas of a place to find something?
Re: small lightweight jack
03/21/2008 10:05 AM
These only have a stroke of about 6" or so, but perhaps something similar?
http://www.hyjacks.com/H21.HTM
Or a scissor jack
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200305253_200305253
Good Answers: 143
03/21/2008 1:08 PM
10/05/2010 11:35 PM
Thanks for the reply,web site helped alot.
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
03/21/2008 2:09 PM
Again with the questions we come. What kind of furniture? Is it tall or top heavy like a refrigerator or bookcase? What kind of surface are you moving it over? Is it smooth and hard, carpeted, stairs, from one building to another, into a van?
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
03/21/2008 9:01 PM
I have already built 2 of these dollies that work together in lifting any load. It currently has a small 2 ton hydraulic bottle jack that works great but is sort of heavy. I'm thinking maybe a ratcheting type or even a smaller bottle jack. I'm looking for something really small that can lift 500 lbs. I dont need it to lift 2 tons. These will be marketed to move appliances and larger pieces of furniture like, book cases ,armoires,desks.
Good Answers: 97
03/23/2008 8:35 PM
A large air bag between plates maybe? Lift could be had by attaching and air pump similar to that used for airbed?
Good Answers: 25
03/22/2008 12:19 PM
One can already buy these "tools" from £1 shops.
(althought some do charge £2 or more.)
It's a simple tubular lever, usually with a small angle
(L shaped) piece at one end, which fits under the
furniture / item to lift, with a handle at the other end
of the lever. (pivot is close to L shape)
When the item is raised a few inches, by inserting the "L"
under the item and levering, a very small wheeled platform is
introduced under the item in various places. e.g. the corners.
They are quite useful. (did my back in once shifting a wardrobe)
because I did not use it. They look a bit "toy town" but work.
jt.
Have a free web page in seconds - on http://www.mfnb.at
03/22/2008 12:43 PM
do you know where i might look for such tools so that i can see if they would work on or with my device?
10/05/2010 11:32 PM
Thanks for your help.The web site looks good
Good Answers: 143
03/22/2008 1:51 PM
You might look at Johnson bars or pry trucks. They have that general shape and function, but also have wheels.
03/22/2008 4:52 PM
HAVE YOU THOUGHT OF AIRBAGS WITH A PORTABLE BATTERY OPERATED COMPRESSOR
Good Answers: 123
03/24/2008 11:47 AM
An air bag capable of lifting 12" would need to be about 24" square. The pressurizing would be very low and could be done with a small hand powered pump as only about 10 PSI would be needed. There is a problem with air bags though. They lack stability. As the contact area becomes smaller, the lifted object acts like it is balancing on a balloon. If you use an airbag type lift use diagonal straps to restrain it. Your plan should work if you run the airbag up until the straps are tight. Good luck.
Bob
Good Answers: 97
03/24/2008 11:35 PM
www.amasci.com/amateur/hovercft.html Give this a try and it's fun too.
Good Answers: 123
03/25/2008 7:31 AM
That does look like a fun project. A pair of RC plane motors and I would have forward motion and steering. This will make the wife's Roomba green with envy.
Bob
Good Answers: 97
03/25/2008 10:33 PM
Be careful playing in the house ha ha!
Register to Reply 15 comments
Anonymous Poster (1); bob c (2); bwire (3); gamundia (4); jt (1); LBrantley (1); Shadetree (1); TVP45 (2)
