Previous in Forum: how to determine speed of rotation of disc in energy meter at full load   Next in Forum: Motor Overload
11 comments
Bus Loading
03/23/2008 7:07 PM
I need to add a new piece of equipment to a busway but I think doing so it will be overloaded. How do I determine if it is...do I need to calc all the full load amps of every piece of equipement that runs off that bus...or detemine the FLA's of only the continuous pieces of equipment
Please help
Engineering Fields - Energy Engineering - New Member India - Member - Jack of all trades
Re: Bus Loading
03/24/2008 2:58 AM
The exercise would be elaborate and involves documentation of all the equipment connected to the bus, their respective power factor and type viz. linear or nonlinear.
What is the rating of the bus and what ampereage you are drawing at present. The continuous rated load should be segregated and diversity of the remaining must be brought out specifically.
Eventually, it is always advisable to take conservative approach as far as bus loading is concerned.
Kind regards,
It takes considerable knowledge just to reaIise your own extent of ignorance.
Re: Bus Loading
03/24/2008 8:39 AM
consider 100% Continuous load+50% intermittent load+0% Standby load
BNDas
Re: Bus Loading
03/24/2008 5:38 PM
j_kamal: what do you mean by "conservative approach" as far as bus loading is concerned
biswanath.das: do you mean the current amp draw of a running load or the fulload amps?...."consider 100% Continuous load+50% intermittent load+0% Standby load"
Good Answers: 39
Re: Bus Loading
03/24/2008 11:19 PM
If the ampacity of the busway is equal to or less than the service entrance fuse or breaker, would that not prevent the busway from being overloaded? Seem to me the whole service would trip off if the total accumulated load exceeded the fuse protection level.
Perhaps the whole service entrance setup should be examined and a fuse co-ordination assessment be done.
Elnav
Re: Bus Loading
03/24/2008 11:50 PM
As rightly pointed out by Mr. Biswanath Das consider 100 percent continuous load and 50 percent intermittent load. By conservative approach, I meant taking into account a larger factor of safety and accordingly derating the electrical system equipment including busbars, switchgear and cables.
Kind regards,
Re: Bus Loading
03/25/2008 6:27 AM
Alternatively you can go by the Incoming breaker rating, if loads are not final at the initial stage of project.
BNDas
Re: Bus Loading
03/25/2008 7:51 AM
Since you do not know how to do this, you should get someone who knows how to do it. Trying ot learn electrical engineering by posting questions to this forum can lead to unsafe installations.
Re: Bus Loading
03/25/2008 8:02 AM
That's correct Mr Blitz. We should be careful while using ideas/suggestion etc. Some people may mislead. It is better to go for a professional consultancy service who also bears the responsibility on the system performance.
BNDas
Re: Bus Loading
03/25/2008 10:05 AM
Compute it? Not on my clock, Junior. Ever hear of an Amprobe? Just measure the current on the supply to the bus with everything on, and derate by 50%. The result? No go-backs if it passes, or the sale of a new load center installation if it doesn't. Everybody's happy, everything works, the 1st time.
Reply Score 1 for Off Topic
Re: Bus Loading
03/25/2008 11:21 AM
Since I am not an electrical engineer I have to rely on advise from the professionals.
Have an electrical contractor hook up an amprobe to give you a printed graph of all loads on the bus bar. The monitoring of the loading may have to be done over a full week or even two weeks to get a complete picture of real life use. Knowing what the peak loading is and when will be helpful. Ask them for loading restrictions on what the code is, and what industry standards are. Have a certified engineer do the math and make the connections. Cover your backside by having somebody who knows what they are doing, insured, show due diligence.
"A problem well stated is a problem half solved." Charles F. Kettering
Re: Bus Loading
03/25/2008 11:59 AM
This is great advice. Thankyou all
Anonymous Poster (2); AquaLungSensei (1); biswanath.das (3); Blitz (1); elnav (1); j_kamal (2); look_hear (1)
