Previous in Forum: Heard of a Quark-Nova?   Next in Forum: "Smart" Barrels to Make Chemical Storage Safer
New Internal Combustion Engine Without Pistons
06/15/2006 11:50 AM
Leel Jayasuriya writes:
I have the prototype design of a new internal combustion engine, that can prove higher efficiency and better performance. I need a partner to build the prototype model of this engine. Please visit http://www.oengine.com for more details.
Pathfinder Tags: combustion engine engine
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
No Piston engine
06/16/2006 6:17 AM
Looks interesting...but how do you seal the flaps on the outer edge with the combustion chamber? I see this having the same issues as the Wankel rotary engine with sealing and blowout.
Nothing is fool-proof to a talented fool
Re:No Piston engine
06/16/2006 9:50 AM
Looks interesting but in addition to the sealing issues, the ratchet mechanism that can be engaged 2500 times per minute will also be an interesting challenge also. That is a lot of impact loading there and those parts would be short lived.
Re:No Piston engine
06/16/2006 11:34 AM
Helecopters(Blackhawks)use a one-way clutch on their rotors so technology is already in place for ratchet mechanism.
Flap Engine
06/17/2006 12:04 AM
Harder to build than a standard piston engine
and I see no mechanical, or efficiency, advantage.
Good calls on the ring and ratcheting clutch problems.
I would also note that you might expect metal fatigue at the
shaft/flapper junction, and cooling problems for the flapper.
(Both sides exposed to combustion gas.)
Also, whence cometh lubrication for the torroidal cylindar walls?
