Previous in Forum: X rays   Next in Forum: what are IC Classification or Application in PCB Assembly
Power reduction of Ovens
03/25/2008 12:59 AM
Sir,
We are using continuous oven for drying of moisture in our industry. But this oven is not fully utilized for time being. After few days/Months we may use the oven fully which is depanadent upon market conditions. In this regard, we are consuming excess power than optimum. How to optimize the power consumption in such a situation. Can we put a dummy plate (of course stop heaters in the removed zone) and reduce the length of oven, so that the partial oven can be fully utilized. This dummy plate will be removed whenever, oven requires to be loaded fully.
Can any one suggest for a better solution or dis-advantages of my proposal.
Good Answers: 266
Re: Power reduction of Ovens
03/25/2008 5:47 PM
Reduce oven temperature testing the moisture content of the product as it comes out. Keep reducing and testing until you get to the level of moisture acceptable for your final product. I would then increase the temperature a bit to cover any fluxuation of the moisture content of the raw material.
03/26/2008 7:05 AM
Ditto on #1's comments. If your process is validated you will have to re-validate the process to the new lower temperature range, most ovens run way to high due to "a little extra heat to be sure" attitude. Using the minimum drying temperature to get your results is best; this usually results in fewer problems with heat damage to your base product too. Also factor in ambient drying time to truly conserve energy (which is cost!). If your product can be "near dry" out of the ovens, and the rest of your process and shelf-life prior to shipping will have it totally dry, this is a way to pinch every penny of energy savings out of your process.
03/27/2008 12:06 AM
Thanks for your comment.
Sir, Can you pls explain how to test the moisture content of the product (Core Coil Assembly in our case). Are there any instruments for testing. Pls. help us where they are available, so that we can do cost benefit analysis and try to procure them.
Thanks & regards
D.Sampath Kumar
03/26/2008 6:55 AM
There is a company that has developed thermal monitoring with power consumption in mind. Check with www.kicthermal.com I know they do reflow and other ovens, and their products may work on your application....
Good Answers: 58
03/26/2008 7:01 AM
If, by "continuous", you mean a belt oven, your best bet may be to keep the thermal load constant by spacing the product uniformly on the belt. The oven controls should automatically reduce the heater power to maintain the preset product temperature and profile. If this doesn't happen, make sure your controls are working properly. You might benefit from a better temperature control system. Check the product temperature profile by instrumenting a part with a temperature sensor and sending it through the oven. You might also check to make sure the oven is adequately insulated. If the oven capacity is seriously under-utilized, consider using a batch oven for small orders.
Good Answers: 80
03/26/2008 9:37 AM
The type of heating elements with respect to the need can be important. Radiation heating (red heating elements) versus convection heating (lots of hot air flowing) can have very different results on the products and overall heat losses. If you use radiation heating, you are usually advantaged to use half of the heaters running at 100% than all of them at 50%. Once again, it depends on the results needed. In convection heating, re-cycling of the air using a condenser to remove most of the humidity can be very effective in the first section (very wet). This is more efficient than continually heating up 100% fresh air. As pointed out in an earlier response, insulation can also add to the saving and to the comfort of the workers.
03/27/2008 12:17 AM
Thank you sir,
In the continuous oven can we use partial radiation heating and partial convection heating. How to know how much of moisture is reduced in the product. Pls. expain method for knowing the moisture content in the product after and before heating, so that we can make any trials.
With regards
D.Sampath Kumar
Register to Reply 7 comments
danuguri (2); jreiche (1); marcot (1); mlimberg (1); ozzb (1); welderman (1)
