Previous in Forum: Degreasing Motor Oil from PE   Next in Forum: A Little Tease or Conundrum???
Measuring % of opaque solids flowing in wastewater
03/25/2008 3:15 PM
Looking for a DYI (low cost) design that allows for non contact measurement of % of opaque solids flowing in wastewater within a 2" clear horizontal Plexiglas tube. Tube wastewater flow rate is variable from 1/8 to 1/2 full. My first inclination is to go optical, but I am unsure how to account for variable flow rates.
Good Answers: 53
Re: Measuring % of opaque solids flowing in wastewater
03/25/2008 7:01 PM
Did you mean that the varying flow rate causes the level to vary from 1/8 to 1/2?
Commercial optical turbidimeters require a full tube. Good luck Guest.
Good Answers: 50
03/26/2008 12:46 AM
You might be able to do what medical personal are counting cells in a fluid - I believe it's called cytology, and it uses laser technology.
Good luck!
03/26/2008 6:07 AM
Use a Markland inline acoustical suspended solids meter. The variable flowrate does not make a difference.
03/26/2008 3:58 PM
Ace Boeringa (1); Anonymous Poster (1); Kilowatt0 (1); vermin (1)
