Previous in Forum: Line Voltage Drop Calculations   Next in Forum: Insulating Gaskets
Flexible Heaters
06/17/2006 3:34 PM
Somen Dhar. writes:
I would like to develop Flexible Heaters. Please assist me how to paste the wire on one side of the Silicon Rubber and then bind them on both sides.What is the binding procedure?
silicon heater
06/18/2006 2:35 AM
I can't help you with your project but someone already makes such a product. If you are making them for your own use it might be easier to buy them. Let me know if you are interested and I will find out the name of the company.
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
Flexible Heaters
06/19/2006 12:29 AM
Check out "pipe trace heaters".
I believe 'Chromalox`- (U.S.A.) is a manufacturer.
Units are available in flexible plastic tape and mineral insulated, (M.I.) cable types.
I would be careful about using silicone rubber for
such a purpose unless you projected outputs are low indeed.
Watlow Heaters
06/19/2006 9:29 AM
Watlow makes these in standard and custom configurations in a few different types of materials. The metal foil is sandwiched (bonded) between 2 pieces of silicone with teflon coated wire exiting the sandwich for power connection. Silicone adhesive is available to withstand +300 degrees C so you could probably make your own.
Pragmatist (1); rcapper (1); silverocks (1)
