Previous in Forum: Thermo-Electric Controllers (TEC)   Next in Forum: EU Cable Color Standards?
Shut-off Well Pump in Case of Flood
06/20/2006 9:20 AM
Jakob writes:
Here is the plan.
Find a relay that allows me to open when I feed a 12 volt puls to the coil. Like a latching relay but than "only open" when the puls is given and remain in the open position until manually reset.
The 12 volt would come from a sensor that detects water on the floor.
This relay would ideally be reset manually, manual reset to reduce energy. In other words only the switch off puls is electric and use energy. When I reset it into the on position manually it will not use energy to stay in the on position.
Who can help me find a relay like that?
Greetings Jakob
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
relay
06/20/2006 1:17 PM
use a DPDT relay, one side controlling the pump, the other side forming a latch circuit. (The relay contacts MUST exceed the pump current rating!)
Re:relay
06/21/2006 6:38 AM
This sounds like a job for a simple circuit breaker
12 vdc coil
06/21/2006 8:07 AM
If I am reading this right all you need is a relay with a 12 VDC coil with some NO and NC contacts. wire it up so when you get your pulse it holds its self in. Wire it through a external NC push button for the reset.
Good Answers: 18
Latching relay
06/21/2006 9:41 AM
What you want is a latching, double throw relay. They're common.
sump pump
06/21/2006 9:57 AM
Ask your local industrial electric supplier for a manual motor starter with a shunt trip coil made by Telemecanique GV2 series. This will allow you to trip the contactor from a remote location. Once the contactor is tripped it must be reset manually, no energy to maintain contacts.
Anonymous Poster (2); Bill (1); CFPscott (1); steve-o (1)
