Previous in Forum: science fair question?   Next in Forum: Ideas regarding chemical engg
Slab heat propane water heater
03/30/2008 10:58 AM
I will be installing 1500 feet of 1/2 inch pex tubing with 25 % gycol in a closed system. I will use a 24 volt dc circulating pump with power from a battery gel cell battery bank charged with a diesel generator and a solar panel. What is the best brand propane water heater and what size btu and gallon tank do I need?
Re: Slab heat propane water heater
03/31/2008 11:15 AM
What you are talking about is a hydronic heating boiler. Weil-McLain makes good units of this type,and I am sure there are others as good. The BTU rating will depend on the size and type of the building, climatic conditions, nature of use (i.e. a building with large overhead doors that are opened frequently in cold weather may need supplemental forced air heat to bring the interior air temp back up after a door operation since floor heat is relatively slow to respond to interior air temp changes). As a guide, in Northern NY climate, our 5200 sq. ft insulated metal shop building with split level 16 ft and 30 ft ceiling uses a 218,000 BTU Weil McLain boiler to serve ~4500 LF of 5/8" tubing in four zones, with a surge tank of around 10 gallons. A good vendor can help in system design for your specific conditions. good luck
Never underestimate the power of stupid people in large groups.
Reply to Forum Thread
