Previous in Forum: Can the Sun be weighed using General Relativity?   Next in Forum: Coplanarity Limit for QFP components
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member Safety - Hazmat - New Member
An idea to mitigate the coming Delta collapse
03/31/2008 8:14 PM
As referenced elsewhere, the Sacramento/San Juaquin estuary (Delta) is under increasing strain, and the poulders which constitute it's principle economic wealth, (farming) will not be sustainable long with rising water predicted from global warming .
When (not if) this occurs, the prior tideland marsh (from 100 years ago) will become an extension of the San Fransicso Bay, with greatly increased salinity.
This will make the water currently extracted at the Southern end of the Delta (to keep all our Southern California friends un-thirsty) non-potable. (as well as having many other undesirable effects on groundwater.
The Delta connects with the San Franciso bay through the Straits of Carquinez.
Consideration should be given to installing a heavy fabric float-supported membrane in the straits which has the effect of reducing salt water incursion during incoming tides. Ship traffic could be constrained to only "low tide" periods, when fresh water outflow is assured.
would this work?
Pathfinder Tags: delta fabric barrier salt water
Re: An idea to mitigate the coming Delta collapse
04/01/2008 1:17 PM
First of all, I do not agree with your assumption that sea levels WILL rise for sure, as there is evidence that either there is no real rise in global temperatures, as measured using sea water and not air temps, and that if there really has been global air warming, that trend has abated.
Second, I doubt commercial shippers will allow this. Also, how would you appease the very strong enviromental lobby in that this barrier, if it can mitigate sea water migration, will also stop animal (and silt) migration.
I do not see this as necessary or practical. Would it work to cure the ill in your proposed scenario? Maybe, for a short period of time - short enough to be insignificant.
04/03/2008 5:18 PM
"First of all, I do not agree with your assumption that sea levels WILL rise for sure, as there is evidence that either there is no real rise in global temperatures, as measured using sea water and not air temps, and that if there really has been global air warming, that trend has abated."
??? I would be delighted if you were correct. Unfortunately, the evidence runs totally against you: as witnessed by (1) ice shelf calving (2) glaciar melting (3) temperature charts, and the correllation between temp charts and CO2 in the atmosphere.
Good Answers: 128
04/03/2008 12:24 AM
I)AVI),
You address one of the related problems facing this unique area. I appreciate your post because it asked a question I hadn't considered. Currently, the land level on the various islands in the delta is dropping due to the farming's converting the incredibly rich peat soil into food crops which are harvested (three crops per year). The dikes at the edges of the islands are already stressed by the wakes of passing ships. In addition, high water levels during flood events have caused catastrophic failure of some of the dikes, with at least one large former island being permanently flooded. In a geological time-frame this is a normal process, but in a human time-frame it is a big problem.
The problem of salinity levels in the waters of the delta has been the subject of law suits and agreements for many years. I am not familiar with the details of any of these (having moved from SF over 30 years ago, and being busy in other fields).
I suggest two avenues to pursue: First, ask this question to the Army Corps of Engineers, who maintain and use the scaled hydraulic SF Bay and Delta model. They may have run this scenario some time already. If they have not, they might find it a good one to study. Second, check the approaches the Dutch are taking with the rivers near their below-sea-level farm lands. They would have more-informed opinions than I. Anything that is done could be quite expensive.
The other post mentioned a problem with silt being blocked, as well as marine animals. These are significant also.
--JMM
04/03/2008 5:22 PM
superb suggestion about the Army Corps..
I'm cognizant of potential probs with wildlife migration,
but if the barrier is dropped when the tide runs out, there should be an amelioration of that issue. Similarly, the slit mostly runs "out" ..
Also, I woudl not see a perfect seal, but one which allows some salt water upstream,
to maintain "historical" saline levels.
Register to Reply 4 comments
Fierce Allegiance (1); I)AVI) (2); jmueller (1)
