Previous in Forum: Overheating Power Cables   Next in Forum: Recharging Dry Cell of Ni-Cd by NI-MH Battery Charger
wiring color code
04/01/2008 3:45 PM
We use the UL508A standard lists for color code can anyone tell me if I use a multi conductor cable from the PLC (24 volt) which is a solid blue color to a terminal strip then leaving the terminal with a multi cable not being blue i color what type of marking are neededif any or can the multi even be used.
Re: wiring color code
04/02/2008 12:45 AM
UL508A is the correct standard. You can also refer NEC.
BNDas
Reply to Forum Thread
You might be interested in: Color Sensors, Terminal Blocks, Color Filters
