I have problem with cables overheat. 480v generator output. The main power cables are going to the main breaker in side the panel. The middle cable is getting overheat at the breaker side. Actually there are two generators and they have the same problem at both generators main breakers sides. The cables are sized for the load. It happened two times. The cables are vertical position crossing bus bars in horizontal position. Is that layout of the cables could make this problem?
Will be grateful for any advice you could supply.
