Previous in Forum: Wavelength of laser diodes for particle measurement   Next in Forum: joining G connection to NPT
calibrating
04/02/2008 11:24 PM
how to calibrate accurately a pressure gauge since its so sensitive?
Good Answers: 53
Re: calibrating
04/03/2008 2:57 AM
Typically a dead weight tester is used as a standard for pressures below 30,000 psi and above atmosphere. But some other precision standards can also be used.
Document as found comparison to standard, equipment used, atmospheric conditions, etc. Make adjustments as necessary. Document final comparison to standard.
If you are interested in how to make adjustment to a specific action please be specific.
