Previous in Forum: related with project   Next in Forum: Class Projects
vacuum -vapor pressure characeterastics
04/03/2008 1:47 AM
What is the criterion to define the vacuum - vapor pressure relations ?
Does any co- relation exist between this two properties ?
We have to set the vacuum & vapor pressure for vacuum condensation of mono ethyelene glycol. The operating pressure is 0.5 Torr . That means we have to have a condeser with chilled water circulation at 10 Deg. what should be the chilled water temp if we have to condense this vapors from 80 Deg to saturation temperature with min possible leakback rate.
please guide or suggest any suitable link.
p.d. gawali.
9423962478
Re: vacuum -vapor pressure characeterastics
04/04/2008 9:20 AM
Your problem needs better definition before any answer is possible. Suggest you find a chemical or mechanical engineer experienced in heat transfer and condensation operations. Failing that, Q=M*Cp*dT + M * dH
Q = heat to be removed (sensible plus latent).
M = mass flow
Cp = heat capacity at constant pressure
dT = temperature change
dH = heat of vaporization at the condensing temperature/pressure.
Q removed from the process stream must equal Q going into the chilled water.
So, chilled water temp inlet temp is dictated by chilled water flow, heat exchanger design, and heat load.
It is also dictated by heat exchanger design where Q=UAdT
U= overall heat transfer coefficient
A=area
dT = temperature difference between the two sides--and is not a constant. Suggest using log mean dT (lmDt).
Refer to the chemical engineers handbook to calculate ore estimate heat transfer coefficients.
All generalizations are false, including this one.
Good Answers: 32
04/04/2008 9:23 AM
Welcome to the forum.
There is a linear relationship between the natural log P and 1/T (Kelvin). So, if you have the vapor pressure and temperature at 2 points, you can plot a line through the two points and get the vapor pressure at any other point.
Tad
Register to Reply 2 comments
