Previous in Forum: What is size limit   Next in Forum: Metallized Polypropylene Films for Lighting & Motor Run Capacitors
Rechargable Battery
04/03/2008 3:36 AM
Dear sir
Please tell me how the charging time, voltage, and ampere of a battery(e.g. 20 AH) is decided?
Re: rechargable battery
04/03/2008 3:43 AM
Best way is to get onto the manufacturers web site, as it depends on the battery chemistry/construction...
I think the AH rating divided by 10 as a current is an accepted 'standard'.
E.G 20AH therefore charge at 20/10 (or 2 as we sometimes call it) amps.
The more important question is deciding when to stop charging and what (if any) is an acceptable trickle charge.
Good Answers: 230
04/03/2008 6:32 AM
Hello Guest,
These days good battery chargers are Computer Controlled, like the charger I use myself.
Here is a good example of a 6+12+24 Volt at 10 Amps Charger for Lead-Acid Car/Truck/motorcycle/Gel-Cell-Lead-Acid batteries.
Apologies for the poor quality of the scans, the unit is excellent, but the paper the instructions were printed on, is rather thin, and the other side has partly scanned through.
Please note the specially designed charging curve, which is different for plain Lead-Acid Battery, and a different curve for the Lead-Acid-Gel-Cell Battery.
Trust that assists you.
Kind Regards....
You might be interested in: Battery Holders, Battery and Fuel Cell Components
