Previous in Forum: Over Excitation and Under Excitation of Generator.   Next in Forum: Yagi Antenna Design
100 % stattor earth fault protection
04/04/2008 6:49 AM
dera sir
what is diffrence between 95 % and 100% stator earth fault protection of generator .how can we calculate the % of protected winding of generator .
regards
suresh kumar paliwal
Re: 100 % stattor earth fault protection
04/04/2008 7:50 AM
What relay are you using? Where are you reading 95% and 100% stator earth fault protection? Do you have differential protection? Are you using directional ground scheme for generator?
04/06/2008 6:22 AM
dear sir
thanks for nice reply.
we are using ABB make RAGEK raly for stator earth fault protection of generator .this relay have two stage for earth fault protection.stage one for 95 % and stage two for 100 % earth fault protection.differantial protection is differant thing and we also have the diff. protection for generator and same is covered under REM543 ABB make relay. also directional ground scheme is here .plese tell me about 95 %and 100% stator earth fault protection
regards
04/07/2008 9:11 AM
Common practice in most countries is to earth the generator neutral
through a resistor. The current through the neutral point resistor will normally
be 5 - 10 A when subjected to the rated phase to earth voltage. For
generators with step-up transformer, a neutral point voltage relay with
typical setting 5 % of generator phase voltage will provide earth-fault protection
for 95 % of the stator winding. It also covers the generator bus,
the low-voltage winding of the step-up transformer and other ancillaries
galvanically interconnected with the stator winding.
An earth-fault close to the neutral point of the generator will not give sufficient
neutral point voltage to activate the neutral point voltage (95 %)
relay. Generators which produce about 1 % or more third harmonic voltage
under all service conditions, can have the entire stator winding,
including the neutral point, protected using a scheme which combines the
neutral point voltage function (95 % relay) and a third harmonic undervoltage
function. Under normal service, typically 40 - 60 % of the generated
third harmonic phase voltage will appear across the neutral point
resistor and will activate the third harmonic voltage relay. If an earth-fault
occurs close to the neutral point, the third harmonic voltage drops to a low
value and the undervoltage relay operates. The relay must have a filter
which prevents the fundamental frequency neutral point voltage from
affecting the third harmonic voltage function.
The 100 % stator earth-fault protection can also be used for generators
with unearthed neutral. The third harmonic voltage between the neutral
point and earth will increase compared to generators with earthing resistor
and the third harmonic undervoltage (100 %) function can cover a larger
part of the stator winding. However, in case of an earth-fault in the high
voltage (HV) network, the zero-sequence voltage transferred to the stator
circuit via the capacitance between the HV and LV windings of the stepup
transformer increases compared to generators with neutral point resistor.
The voltage setting or the time delay of the generator neutral point
voltage (95 %) relay must then be increased to get selectivity against
earth-fault relays on the HV side.
Follow this link for detailed info..
http://library.abb.com/GLOBAL/SCOT/SCOT296.nsf/VerityDisplay/108DF8A9ABA23809C1256E4E0054CBBB/$File/1MRK504006-UEN-1-en_Users_Guide_RAGEK_100__and_95__stator_earth-fault_protrection_for_generators.pdf
Re: 100 % stator earth fault protection
08/25/2010 5:26 AM
Dear Sirs,
I am new to the protection world. How can I learn about 95% and 100% stator earth fault protections based on low frequency injection? I have tried to read it from internet but alas, i could not figure out the circuit, how does the 20Hz freq generator, filter unit help, where it is injected, what is the feedback signal etc.
All I know about 100% stator E/F protection is that the voltage generated between the neutral point to the 5% of the winding is very less during an earth fault which will be undetected by the 95% Stator E/F relay, Hence we use a Low freq injection or Third harmonic protection scheme. At present I want to study about the low freq injection schme w.r.t REG316 Relay which uses some hardware like REX010, 011 etc.
Help solicited,
Abbs
Register to Reply 4 comments
abbs (1); Anonymous Poster (2); ekiechle (1)
