Previous in Forum: 1000kwt inverter for home use   Next in Forum: Case studies on Electrical Power failures in Oil refinery
CABLE JOINTS & TERMINATION
04/07/2008 3:07 AM
Lets now be more specific:
Need step by step procedure of cable termination.
Heat shrinkable indoor termination 17.5kv, 3 x 300mm sq mm AL conductor cable XLPE, With wire screen and tape armoured with right angle boot.
Good Answers: 27
Re: CABLE JOINTS & TERMINATION
04/07/2008 9:07 AM
The step by step procedure will be included with the termination. Otherwise check the manufacturer's website for those instructions.
Good Answers: 42
04/07/2008 10:16 AM
The cable jointing is a job of skill and should be done only by a competent and trained cable jointer. How ever I can give you some guide lines.
1) You must ensure that the kit is suitable to your voltage and size of the cable.Manufacturers provide these details with the jointing kit.
2) The manufacturers provide a check list of the items which you must verify before starting the job.
3) Must use a sharp knife ( special cable jointer's knife is available),LPG gas torch.and proper cleaning cloths and solvents.
4) The outer sheath , armour, inner sheath,should be cut exactly as per the dimension as per the instruction given with th kit. Manufacturers specify that.
5) You should use only the solvent supplied with the kit for cleaning.
6) Adjust the torch to obtain a soft blue flame with yellow tip.
7) The stress control tubing should not be cut.
These are only some important precautions.You should entrust the job only to an expert or manufacturers jointer as a bad termination will be a cause of breakkdown. .
04/13/2008 4:50 PM
you can call me on 0503197355 , that i am working in s.e.c
Register to Reply 3 comments
Bluestone (1); emadhamor (1); V.I.Abraham (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
