Previous in Forum: PME   Next in Forum: Pressure Balanced Expansion Joint
Jam nut preload
04/07/2008 4:13 PM
Generally, you preload a bolted connection to keep the surfaces from separating.
With a jam nut THIS NUT IS INTENDED FOR USE FOR POSITIVE LOCKING OF ROD END TERMINALS TO HYDRAULIC PISTON RODS, TIE ROD ENDS, PUSH-PULL RODS, ETC
So, if you have a bolt directly tapped into metal (tapped threads), and use a jam nut (with a locking feature) to keep the bolt locked in there, could a tension load higher than the jam nut preload separate the connection? I would think no, and it would require a torque load to "unspin" the connection.
thoughts?
J
Re: Jam nut preload
04/07/2008 5:34 PM
I dunno. If I were worried about the threads backing out I would use LocTite (or similar thread locker). The stuff works. When you need to get it out, heat the joint up with a torch. It will back right out.
Peace be upon you.
Reply to Forum Thread
