The project I am working on is to take an existing system, and make it run faster by applying lean principles. What I am trying to do, is to take a CNC lathe operation, where we are running many different parts daily, and eliminate some of our set-ups. The parts we make are of various size and material, from HR steel burnouts, to grey iron castings, to cast aluminum, and range in size from 2" to 11.5" in diameter. Some parts only require one operation, and are held with hard grippers. Others require two ops, and the first is held with hard grippers and the second is often held with soft jaws that we turn in the machine ourselves.
So, we have many diameters that are required to hold on (without marring the turned surface) and therefore about 30-40 different top jaws in a very messy drawer. What I want to do is make a self-adjusting jaw that can grip on a fair range of diameters and limit the number of jaws I have to own to 3 or 4. I can't sacrifice on accuracy of my parts, and I can't scratch the surface of the turned parts. My theory is that I can use pendulum style top jaws, with a soft polymer, rounded insert, that will deform under load to give me a good grip on the part. For the insert, I am considering Nylon, Polyethylene, and Acetyl as materials. Has anyone tried this before? I believe this may work, and I intend to try it, but I'd like to know about anyone else's experience on this.
