Previous in Forum: Fire extingushing systems   Next in Forum: recycling used lubicant oil
27 comments
polymers
04/09/2008 11:47 AM
what clear "wood"protectent is best for outdoors? on older log cabins,"solid Logs"in eastern NC. temps,ranging from 100 degrees in summer to 20 degrees in winter?
Good Answers: 97
Re: polymers
04/10/2008 12:11 AM
Start with a product named "CWF" (Google) yes it means 'clear wood finish' and is exceptional, the product line includes a restoration chemical process to redeem weathered wood surfaces too.
Re: polymers
04/10/2008 7:55 AM
Wood varnish or clear urethane paint.
Good Answers: 27
Re: polymers
04/10/2008 9:05 AM
I'd go with Thompson's Waterseal. It's probably the best known brand in North America and would protect well in your environment. (You can also review the active ingredients on the Thompson's label and purchase lower priced equivalents; both oil and water-based at places like ACE Hardware).
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
Re: polymers
04/10/2008 11:16 AM
What is better, water or oil based sealant? Is it better to use a water sealant product with un-treated wood, or use treated wood alone, or treated wood + a water sealant? I am having a house built and thought about this the other day in regards to fencing.
Good Answers: 97
Re: polymers
04/10/2008 11:34 AM
Treating treated wood is a waste of treatment. Use treated wood or synthetic...
Re: polymers
04/10/2008 11:39 AM
Yes, that is what I thought...but then is it better to use pre-treated wood from a hardware store, or is the untreated wood with Thomson's water seal better?
Good Answers: 97
Re: polymers
04/10/2008 4:00 PM
Is better to use the pre-treated wood that is pressure treated; 'Sunwood' is an example but better products are now available.
www.strongtie.com/productuse/PTWOODFAQs.html
Re: polymers
04/10/2008 12:22 PM
building A double-porch and balcony,using old telephone poles as supports.What would be The best clear-coating on these poles?THANKS FOR YOUR INPUT!
Re: polymers
04/10/2008 12:41 PM
Aren't they already coated in creasote?
Re: polymers
04/10/2008 2:29 PM
yes,they are already covered in creasote,however being old poles the're mighty rough to the touch,so when my grandsons try to climb up them or slide down them,which I know they will,they won't get slivers!
Re: polymers
04/10/2008 2:33 PM
Gotcha. Sanding or planing seems like it would take forever. Maybe you could just wrap them in burlap or something with maybe some padding material. How about old railroad ties? I know you already have the telephone poles, but if you can get your hands on some old railroad ties, they are great for things like that.
Re: polymers
04/11/2008 7:53 AM
The storage and use of creosote is now heavily regulated in the UK. Substitute self-application products are available, though with less attractive prospects as regards long-term performance of the timbers they protect.
Good Answers: 97
Re: polymers
04/10/2008 4:05 PM
I'd wrap the poles with rope then leave them be or then coat with 'Deft'
Re: polymers
04/10/2008 1:52 PM
Hi rockfishjr. I hope you get some good answers here. I am in the process of cutting down pines which I will have sawn into beams for a barn. I am particularly concerned about insect attack, since the beams will be "green". I hope to find a "homebrew" formula for a treatment that will protect from borers as well as fungal attack.
Bill Morrow
Bill Morrow
Re: polymers
04/10/2008 1:57 PM
Oh, and I have a similar climate here in central Alabama as do you in eastern NC. Termites destroy any wood structure in contact with the ground within 2-3 years.
Bill Morrow
Good Answers: 97
Re: polymers
04/10/2008 4:06 PM
Checkout post 13
Re: polymers
04/10/2008 8:31 PM
Men are like steel, if they lose their temper they are worthless.
Re: polymers
04/11/2008 10:09 AM
Gary-
Thanks for the site. Pentacryl is good for stopping shrinkage in small items like lathe-turned bowls. To be effective the bowl must be submerged for days in a heated solution in order to displace the water with polymer. Obviously this would not be practical (or affordable) for beams. What is needed is an anti-vermin, anti-fungal solution. A sealer such as urethane, polyester, or penetrating oil would probably not be appropriate because they would interfere with the re-application of preservative. But, then, I'm no expert. That's why I am asking for help, too.
Bill Morrow
Bill Morrow
Re: polymers
04/11/2008 12:12 AM
For an incredibly durable clear coating try polyester resin. It's about $35 a gallon, including hardener, stretches a long way and leaves a plastic coating on wood that is water impermeable.
Protection from excess moisture is the key to the longevity of wood. Given enough moisture, even pressure treated lumber rots. Keep lumber dry and it will last for many years.
Re: polymers
04/11/2008 11:54 AM
THANK YOU!!! I thought there was A product out there that would be for my needs.POLYESTER RESIN,A smooth, clear,hard surface,that blocks moisture and is very durable.JUST WHAT I WAS LOOKING FOR!!!THANKS AGAIN!!!
Re: polymers
04/11/2008 12:12 PM
Polyester resin is indeed everything that Cornelius says. One thing it is not, however, is flexible or elastic. If the wood is subject to expansion/ contraction due to changes in humidity the resin will crack. Once cracked, it will allow moisture to get into the wood, then hold it in, accelerating rot. I would think a penetration oil, while still not perfect, would best serve your need. It should contain at least 50% tung oil, and penetration can be enhanced by adding a thinner. It would need to be re-applied every 1 to 5 years.
Oh, and I don't mean to hijack your thread. Since my need is so similar to yours I thought I could piggyback and we both might benifit.
Thanks,
Bill Morrow
Bill Morrow
Re: polymers
04/13/2008 9:26 AM
It is correct that polyester resin is rigid to a degree. Nevertheless, it does have a coefficient of expansion which depending on the wood can be similar. It is used on wooden marine hulls every day. Whether it cracks from a dissimilar thermal C.O.E. depends on the thickness of the resin and preparation of the substrate.
Good Answers: 97
Re: polymers
04/13/2008 4:34 PM
Aye, then wind rope around the posts and coat with resin so the little tike's can climb and frolic without harm.
Re: polymers
04/14/2008 4:17 PM
"it does have a coefficient of expansion which depending on the wood can be similar"
Yes that is true. However, coefficient of expansion describes the expansion/contraction with variations in temperature. The problem, I think, comes with expansion/contraction of the wood due to variations in humidity.
I remember spending many long, hot afternoons as a "youngun" lying on my back scraping the peeling resin from the underside of a mahogany boat hull. If there were a perfect system for sealing wood I guess everyone would know about it already.
Good Luck!
Bill Morrow
Bill Morrow
Good Answers: 97
Re: polymers
04/14/2008 11:30 PM
think the point you are trying to make is contingent upon the realization that the coefficient of expansion is close to that of wood when both are immersed in water.
However in this application being that one part of the post surface may be bathed in intense sun light the opposite may be in cool shade rendering the aforementioned coefficient moot.
Re: polymers
04/15/2008 11:05 AM
I wish I had said that.
I wish I COULD say that.
Bill Morrow
Good Answers: 97
Re: polymers
04/16/2008 1:38 AM
Go on an say it (:
Register to Reply 27 comments
Bluestone (1); bmorrow492 (6); bwire (8); corneliusvansant (2); garyceng (1); Nelson de Leon (1); PWSlack (1); rockfishjr (3); Vandarye (4)
