Previous in Forum: Boiler   Next in Forum: Shaft alignement
boiler
04/10/2008 8:25 AM
we have got a chimney of 121mtrs. of height. At 119 mtrs there is given some horizontal plates. Why? At outer periphery why fins are provided?
Friend of CR4
Re: boiler
04/10/2008 4:48 PM
With all these questions posted about boilers, you should take a class on the subject.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Good Answers: 19
Re: boiler
04/11/2008 12:18 AM
All your Boiler questions are falling in a pattern that either you are totally new with boilers or come across a book already and fished out all these questionoun o help ys.
Read as:
All your Boiler questions are falling in a pattern that either you are totally new with boilers or come across a book already and fished out all these questions.
Good Answers: 19
Re: boiler
04/11/2008 12:16 AM
Check up your Boiler file and ask the chimney manufacturer as to the Why.
Suggest you go to your local library and pick up all books on Boilers, read and do your own assignments.
Prior answering all yourl your questions but first I want you to email me your CV with educational & job description to assure that you are in this job.
Register to Reply 3 comments
