I wish to purchase equipment to leak test underground fuel tanks at service stations, etc in australia. often the only access is down a 50mm diameter dip stick tube. Many of the tanks have a high ground water level, so the test must also detect water ingress.
I am familar with some of the test systems in use petrotite, masstech, tanknology, ustest etc
I am looking for the fastest and most accurate, that can be purchased outright.
