Previous in Forum: Anti collision device in tower crane   Next in Forum: About Numerical Relay
calculating cable size
04/12/2008 10:15 AM
Hi anybody can briefly say how to calculate cable size with calculation for 10kw starter for 100mts distance between MCC to Motor
Re: calculating cable size
04/12/2008 11:25 PM
A little more info would help...
What voltage?...is the cable buried or on cable tray?...
i am assuming it is underground and the voltage is 3 phase 415 volts, current 24 amps,..
3 core X 10 sq mm will do the job.
Cheers.
Cheers
He must be very ignorant as he answers all the questions he is asked. Voltaire
04/13/2008 8:40 AM
thank you very much, but similarly i have more motors with diffrent voltages, so pleae advise step by step what can i want to do
04/14/2008 9:49 AM
Hi,
In this case first should know that type of material, of which the cable will be made. Now we can calculate the size of the cable using following formula.
Now,
R = K * l/A
Hence,
A = K * l/R
Whwre,
K = Coeff. of conductance
l = length of the cable
R = Resistance
Regards,
J. P. Mishra.
Register to Reply 3 comments
Anonymous Poster (1); chaterpilar (1); rts_sathish (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
