Previous in Forum: House plumbing question.   Next in Forum: Accurate cutting of picture framing
Which epoxy to use for adhering a metal framed fixture to a mirrored wall?
04/14/2008 9:59 AM
I am trying to attach a light fixture (3 ft long and 6 inches high, 2 inches deep, 10lbs) to a mirrored wall. The light fixture is located in the bathroom. It is to be glued to the mirror. The light fixture material is chromed sheet steel.
Which epoxy should I use?
I prefer something fast curing since I have to somehow hold the light fixture in place until the epoxy is fully dried.
Thanks in advance.
Two silk worms had a race. They ended up in a tie.
Re: Which epoxy to use for adhering a metal framed fixture to a mirrored wall?
04/14/2008 10:36 AM
I would recommend
http://www.liquidnails.com/ViewProductDetails.do?productId=54
or one of their other products. I'd be afraid that epoxy would never come loose.
Good Answers: 40
04/14/2008 3:03 PM
Don't !
The building code requires light fixtures to be attached to the frame of the building.
Good Answers: 97
04/15/2008 1:24 AM
techno is correct but if he wasn't a polymer adhesive would be best.
Polymer adhesives on Global Spec, Master bond polymer adhesive EP21TP-2
04/15/2008 9:51 AM
Billy Maze sell epoxy that everything sticks to everything.
I'd be worry that the mirror will pull off from the wall. Better secure to a stud.
Register to Reply 4 comments
bhankiii (1); bwire (1); spyonabird (1); techno (1)
