Previous in Forum: PIR detection and solar power   Next in Forum: Solar Hybrid Plus Batteries System Proposal
relay module timer for PIR detector
04/14/2008 11:58 AM
If I use a PIR detector to trigger a relay mosule, how can I determine how long (in my case 12V DC) the trigger out will be enabled?
Re: relay module timer for PIR detector
04/14/2008 12:37 PM
PIRs usually have a control for the ON time, built in. If you didn't want to use that, you could use e.g. a 555 triggered by the start of the PIR ON signal, and use that to drive your relay.
04/14/2008 2:01 PM
Any suggestions for an outdoor rated PIR that is of good quality and fair price?
04/14/2008 5:06 PM
Sorry, mate - I think they're all much of a muchness. Don't know where you're from, but round here I'd just go to any of the big DIY places. Most of these things are made pretty well - they'd be it trouble if even 5% were returned U/S - that would be thousands of them! The manufacturer would be kicked off the books as a supplier to the DIY chain - so they have to be a bit careful.
Hope this helps.
Register to Reply 3 comments
