Previous in Forum: Pipe minimum allowable thickness   Next in Forum: relay module timer for PIR detector
PIR detection and solar power
04/14/2008 11:03 AM
I am working on a CCTV project. We need a low power PIR module for triggering a solar powered system when movement is detected. We are planning on using an Altronix relay module for 12V supply at approx 2500ma. What detectors are available?
Re: PIR detection and solar power
04/15/2008 3:37 AM
Hi Roger,
I can provide such a device as I have a design that I have used on several projects and that is quite low power and can be adapted. Can you provide additional specifications such as the required operating range, the available power and how many units you would require?
rcapper
04/15/2008 5:59 AM
My PIR sensor design draws 35 microamps. Of course turning on a relay would incur additional power but I am using a latching relay in one design so that continuous power is not required.
04/15/2008 5:17 AM
Hi You find the Dynalite DUS 704 or the wall mount will do what you want coupled with their relay depending on your current requirements. The control voltage for both is 12VDC and the current would be < 100 mA per unit. /http://www.dynalite-online.com/Product_Docs/dus704/Documents%20-%20Public/DUS704%20Data%20Sheet%20Rev%20C.pdf
Mark Taylor, Senior Technical Advisor, CV Bli Tek, Bali, Indonesia.
04/15/2008 7:49 AM
Sorry but we could not find DUA 704 in the product line for Dynalite. Please assist
04/15/2008 9:31 AM
DUS not DUA
rcapper (2); Roger TN (1); Tamu (2)
