Previous in Forum: Tippers unloading   Next in Forum: What's the Craziest Thing, Must be Genuine, that You've Ever Seen a Motorist do?
Silvani Actross Fire Truck
04/15/2008 2:38 AM
what could be the possible problem(s) with a Silvani Actross fire truck of 1998 model getting difficult to start.
I desire possible solution(s) to this challenge.
Good Answers: 114
Re: Silvani Actross Fire Truck
04/15/2008 11:49 PM
I think you should adjust the nut behind the wheel!
04/16/2008 12:00 AM
There are three things an ICE engine requires to start. Compression, fuel, and ingnition or spark. Check each one carefully.
Engine should turn over easily, i.e. well lubricated, normal compression, etc.
A good grade fuel should be supplied by carburetor or injectors in the correct amount at the right time.
Spark plug should be clean, proper gap, and furnished with the proper high volatage at the right time. Check the distributor and high voltage wiring.
Modify the above list to adapt it to your particular engine.
04/16/2008 1:13 AM
sir, what part of the system is challenging to start?
the tractors main engine itself? the diesel engine powered water intake pumpsystem or is it the high presure discharge pumping unit?
relating what part of the fire truck's components you are experiencing problems with in a way that is understood by the persons you seek answers to your problems from is half way to having them solved.
'da ber
04/16/2008 8:44 AM
"sir, what part of the system is challenging to start?" SQ 4,129
The engine of course. I don't connect anything to it until it is running!
That is why there are gear boxes etc.
Good Answers: 123
04/16/2008 8:53 AM
Please explain what engine is used in this fire truck. I am not familiar with that brand.
Consider the age of the fuel in the truck. Has the truck been used enough to keep the fuel changed regularly? Has algae started to grow in the diesel? Has anything changed since the truck started well? The more information you can provide, the more hopefully this site will be.
Bob
04/16/2008 10:49 AM
Bad fuel, bad fuel pump, dirty fuel filter, dirty air filter, bad battery, bad spark plugs or bad glow plugs, engine sluge, bad starter, dirty injectors, worn rings, wrong weight motor oil, corrroted ground, bad battery cables, ect.ect!
Register to Reply 6 comments
Anonymous Poster (2); bob c (1); Garthh (1); jmart23 (1); Stirling Stan (1)
