Previous in Forum: 40hp, 460V, 60hz, to run on 380V, 50hz,   Next in Forum: How to improve power of a sinusoidal wave???????
Motor starter idea
04/15/2008 9:36 AM
hi engineers
i would like to know what is the idea to have two panels one as supply motor and the second used for starting i have these in our system with BOOSTER PUMPS
please in help regarding this cause i feel I am uncomfortable till i understood this
your cooperation regarding above questions will be highly appreciated
Good Answers: 804
Re: Motor starter idea
04/16/2008 1:43 AM
It's obvious that English is not your primary language, but I for one am having difficulty understanding your question. Can you try to provide more information?
Are you asking why someone would have two pumps in series as a booster station? If so, it is not an electrical issue, it is a mechanical one.
04/16/2008 2:45 AM
thanks for your reply
yes english languge my second languge but i think this is not make different
how do you know that ?
any how
what i need to know is why we do use the motor starter i mean in big pumps we should provide motor starter panel in switchgear why we don't use it in the small pumps ?
your cooperation is highly apperciated
04/16/2008 8:21 AM
The power to start a large motor (especially a compressor) is much greater (order of 6X) than the power to keep it running, even under fully rated mechanical load. Some motors have "starter' windings and a centrifugal switch to disconnect them once the motor is up to speed (otherwise they may burn up). Some motors require a separate, higher rated starting feed input. It does not pay to guess - check with the manufacturer's instructions and specifications if in doubt.
Register to Reply 3 comments
Anonymous Poster (1); ema (1); JRaef (1)
