I have 2 Incremental hollow shaft Encoder type BHW and BHG from Baumer (They produce 3 squarewaves signals, check datasheet!)
here are the Datasheet:
1.http://sensor.baumerelectric.com/productnavigator/downloads/Produkte/PDF/Datenblatt/Winkel_und_Positionsmesssysteme/en_E_1DG_BHW.pdf
2. http://sensors-transducers.globalspec.com/SpecSearch/PartSpecs?VID=92284&Comp=7&PartId={dad9ebfb-1b5c-465c-93d3-f61c689c2c2e}
The thing is implemented in a joystick in a helicopter, so it will have some axis. What i need is a ready existing (that i can just order it) interface box that may produce voltage between 0 and +/-10V (or 0 and +/-5V, or as long as it is analog).
The box need to be strong and as small as possible...
Anybody has recommendations??
Thank you for replying!!
Cheers,
Brian Angg
