Previous in Forum: I need a lightweight plastic spool valve >100psi >10mm   Next in Forum: Sizing Exhaust Gas Vent on Condensing Furnace.
Injection molding screw
04/17/2008 9:16 PM
Can any body help me to find the correct formula for calculating the compression ratio of General purpose injection molding screw?
Good Answers: 16
Re: Injection molding screw
04/18/2008 11:10 PM
You might try the following forum to pick the brains of injection molders:
http://www.feedscrewdesigns.com/cgi-bin/forums/Ultimate.cgi
Regards, Delmar Schmidt
Melfi Technologies Houston
www.melfitechnologies.com
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
04/19/2008 8:13 AM
The compression ratio is a comparison between the depth of the feed section of a screw in relationship to its metering section. You get this this by measuring the height of the top of the flight at the feed to the OD of its root. Do the same for the metering section and then divide the metering height into the feed height.
C.R. = Depth of Feed/Depth of Meter
Example: For a 2" diameter screw
C.R. = .340"/.170" = 2:1
"Imagination is more important than knowledge. Where knowledge is limited, imagination encompasses the Universe"
Register to Reply 2 comments
